06-10-2021
14:41
06:18
06-10-2021
14:41
06:18
Hello
My left button / back button won't work I can hear it clicking like if it should work but nothing. When you go into a app you can't get out of it. I've tried doing a factory reset but still nothing working can anyone help?
Thanks
06-11-2021 06:19 - edited 10-25-2023 16:36
Hi there, @Keireen. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
Please try to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air, just hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button. Then, please try restarting your Versa by following these steps.
Hope that helps.
Best Answer06-13-2021 08:59
06-13-2021 08:59
Hello
Just tried that and still nothing happening I can't even reset it as it say i have to hold the button down for 10 sec but it the button what not working. You can hear the button clicking but not working at all.
Thank you
Best Answer06-14-2021 06:41 - edited 08-29-2023 10:11
@Keireen I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
