Versa button isn't working
My button on left side don’t work and it won’t sync unless it’s in the charger.
2 REPLIES 2
Try restarting it several times.  If that doesn't fix it try a Factory Reset (Settings app on your Versa and scroll down to About).  If the button is still not working you will need to contact Support (link in my signature)
Restart your Tracker
Community Council Member
Helen | Western Australia
It's great to see new faces @Douglas3po, welcome and @NellyG thanks for the input.
If your Versa button isn't working, you may be able to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air. Hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button.
I hope this helps, let me know the outcome. Man Happy
