02-17-2019 16:36
02-17-2019 16:36
I have driven my motorhome for the last 4 days. It registered over 10k steps everyday and that I had even did 88 floors one day and 86 floors on another day! Not bad for sitting driving a motorhome! Definitely something wrong with the algorithm.
02-17-2019 20:30
02-17-2019 20:30
@Callander Unfortunately as Versa is a wrist tracker it will register bike rides. There's no way around it for now. You can try changing Wrist Placement settings in your Fitbit mobile app to Dominant and that should shave off a few steps, but the main issue remains. I would suggest manually logging Driving activity for that time period in the Fitbit mobile app to remove the ghost steps. Alternatively, you can use the Drivebit app.
02-17-2019 20:30
02-17-2019 20:30
02-18-2019 04:08
02-18-2019 04:08
02-18-2019 07:08
02-18-2019 07:08
There are also 2 apps made to help here
Drivebit
Travelbit
02-18-2019 14:37
02-18-2019 14:37
@Callander I would give it a try nevertheless. Alternatively, you can try the app @Rich_Laue has mentioned. 😄
09-28-2020 12:41
09-28-2020 12:41
Definitely is something wrong with the app. I've been driving for 6 years and I never have had such result. I'm using Drivebit app.
10-29-2020 22:34 - edited 11-01-2020 21:22
App sometimes count steps when I'm driving, sometimes not, I also use the Versa app. I think it depends on the roads, if the road is hilly then the app can consider it as if I was going up the floors. Often I also go on an off-road trip, after which I have to use the rv detailing that my friends do me at a discount. I used to use a different app, I don't remember which one, it worked even worse. And my friends advised me the app which works exactly when you're driving. This turned out to be very convenient for me as I often travel. If you are using a more accurate application, you can advise me it.
10-30-2020 07:32
10-30-2020 07:32
Basically, depending on how smooth the road is, bumps, and the cars suspension a person may or may not find steps counted during a ride.
