Versa clock changed to Layers by itself and I can't remember or find the one I have been using for the last year
Hi, were you using a Third Party Clock Face? If yes, then there is the possibility that Fitbit changed you Face to Layers, cause either your TPCF has expired of has been removed by either the developer of Fibti itself whilst cleaning up the Gallery. If this is the case, you should be glad that Fitbit changed your clock face, otherwise you would encounter a lot of problems with a non-working clock Face.
Best AnswerHi, were you using a Third Party Clock Face? If yes, then there is the possibility that Fitbit changed you Face to Layers, cause either your TPCF has expired of has been removed by either the developer of Fibti itself whilst cleaning up the Gallery. If this is the case, you should be glad that Fitbit changed your clock face, otherwise you would encounter a lot of problems with a non-working clock Face.
