Versa clock faces issues
EDIT: Nevermind, it's fixed: I'm dumb and didn't notice you had to tick the various permissions when you install the clock face (I thought they were just listed). Could a mod please delete the topic? Thanks in advance!
Hello,
I've been having trouble with a Fitbit Versa I bought this week. Most of the clock faces don't display my stats, despite numerous soft and hard resets. The only faces I don't have that problem with, are all the ones from Fitbit, except for the soccer one, which has the same problems.
I have tried numerous soft and hard resets, uninstalling and reinstalling of the app, etc.
Considering the ones that work, I'm not sure whether it's a software or hardware issue? I should maybe add that at some point for two of those faces, the heart rate was displayed for a bit (not the other stats) and then vanished again. Any tips, please?
1 REPLY 1
It's great to see new faces @coffeegee, welcome.
Thanks for troubleshooting this by yourself, I am glad to hear that you were able to solved your clock faces issue. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! Robot Happy
