12-09-2020
04:43
05:12
JuanJoFitbit
12-09-2020
04:43
05:12
JuanJoFitbit
My Versa started to constantly restart (all I see is black or the logo), seems I can't do anything else.
I have not changed any setting s or screens in weeks, it just started doing it about an hour ago, hasn't stopped since. Tried factory reset (3 buttons), no effect .... Any ideas what else I could try??
Thanks!
12-09-2020
05:12
10:06
12-09-2020
05:12
10:06
Hi @cdorfer, welcome to our Fitbit Community. Regarding the random and constant restarts issue that your Fitbit Versa has experienced, I appreciate the time spent trying to get this issue resolved before contacting our forums.
I'd like you to try a regular restart. To do so on your device, follow the steps listed in this help article. After this, try setting up your watch from scratch and see if the issue gets fixed.
Keep me posted on the outcome.
10:20
10:06
12-09-2020
10:20
10:06
Hi @cdorfer, thank you for trying the restart process. Since the issue persists, I'd like you to try one more workaround, which has been helpful for this type of issues. Please try a factory reset. To do so on your device, follow the steps below:
Let me know how it goes.
Best AnswerHi JuanJo,
tried it, but after holding the left and top right button one minute plus, nothing happens, screen is blank, no vibration. After I let those 2 buttons go, the constant on/off resumes...
09:18
10:06
12-10-2020
09:18
10:06
Hi @cdorfer, thank you for getting back and trying the recommended troubleshooting steps. Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any question arises.
