05-14-2018 18:24
05-14-2018 18:24
My versa is not working I can’t turn it on and I kept it on the charger for 2hours
Best Answer05-14-2018 18:29 - edited 05-14-2018 18:30
Try holding all three buttons for about 15 seconds. See if that does anything. Also could be that your charger is a dud (some seem to be having charger issues). Maybe try a new charger as your last resort if your return/exchange window is gone?
Also, into what was the charger plugged in?
05-14-2018 18:30
05-14-2018 18:30
Thanks I try dat
Best Answer05-14-2018 18:31
05-14-2018 18:31
No problem, let us know 🤗.
Best Answer05-14-2018 19:03
05-14-2018 19:03
Mine died also. Returned mine and just got my replacement today. Good luck.
Best Answer08-06-2018 11:14
08-06-2018 11:14
Unfortunately, same thing happened to me!
It was just on 60% and then it all went black. I tried re-charging. The interface goes back up but won't get past to 1%. Once you take it off the charger, it's just dead! I tried to troubleshoot + factory reset but nothing works.
I contacted customer service. The chat agent was great. I am now doing an e-mail exchange. They decided that it might just be the charger with all the videos I sent. They'll be sending a charger replacement instead. I'm from the Philippines so imagine how long will that take. Imagine also the frustration when I try the new charger and it still doesn't work and it ends up being the hardware fault at all.
Oh! Quite frustrating!
Best Answer12-04-2018 06:41
12-04-2018 06:41
I am having similar issue, I am unable to start my versa. It’s fully charged. Screen first blanked and then it died. Any suggestions
12-04-2018
08:16
08:37
12-04-2018
08:16
08:37
@Mamtahv It's great to see that you've visited the Fitbit Community! Sorry to hear that your Versa isn't working. Try cleaning the contacts including using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this restart your device and see how it behaves.
Let me know how it goes!
