05-07-2018 18:55
05-07-2018 18:55
How can I change the dominant hand setting on the versa? I can’t find it
Best Answer05-07-2018 19:06
05-07-2018 19:06
Open your Fitbit mobile app, click on the right top corner to open your account, then click on your Versa and you should find the setting on which hand you wear your Versa on.
Best Answer07-24-2019 21:38
07-24-2019 21:38
Right is my dominant hand and i were my watch on my left so in wanna set that as the hand my vera is on
Best Answer07-25-2019 03:20 - edited 07-25-2019 03:25
@JNR2019 The setting for you will be non-dominant. You should not need to worry about this. I believe that non-dominant is the default setting.
Laurie | Maryland
