06-12-2018
16:44
10:34
AlvaroFitbit
06-12-2018
16:44
10:34
AlvaroFitbit
hi everyone... wondering how many exercise options do others have I qas told there were 15 to choose from with the vers and I only have 7... it wont even track my walks
06-12-2018
17:05
06:26
AlvaroFitbit
06-12-2018
17:05
06:26
AlvaroFitbit
You can switch them out from the Fitbit app under “exercise shortcuts.” There are 15 to chose from but you can only use 7 at a time. Walk is one of the options.
06-14-2018 06:41
06-14-2018 06:41
@Brittanyjuric Welcome to the Fitbit Community! It's great to have you here! Like @Jayelo said you can select between several exercise options but can only have 7 set on your Versa. Please go to your Versa settings and select the exercise you want to have, save and sync these changes.
Let me know how it goes!
06-14-2018 18:10
06-14-2018 18:10
07-02-2018 08:10
07-02-2018 08:10
@Brittanyjuric sorry for the delay in my reply. Happy to hear that you were able to setup the exercises on your Versa. The mode you are talking about is Connected GPS. You will need to link both your phone and your Versa at the start of your exercise, once you see the app that they are linked you can start your activity. When finished try syncing them before stopping the activity and you should get a GPS map. You can check more about the Connected GPS feature here.
08-28-2018 07:30 - edited 08-28-2018 07:30
Hi
I do not have all these options on my versa mobile app...only 7 ; walk, run, outdoorbike, elliptical, sports, aerobic workout and swimming...why is that?
Thank You
08-28-2018 08:24
08-28-2018 08:24
@Nohazem Your Versa can only load seven of the exercises at one time. When you are your list of Exercise Shortcuts on the mobile app, tap Edit and choose something that you don't use and delete it. Now the + Exercise Shortcut will turn blue. Now you can get to the rest of the exercise list. Now you can customize your list.
Also, when you are on the Edit screen, you will see the three lines on the right of each exercise. If you lightly touch and hold the three lines, you can move a shortcut by dragging it into your custom order.
Laurie | Maryland
08-28-2018 10:20
08-28-2018 10:20
@Nohazem Welcome! It's great to see you around. As @LZeeW explained you will first see the options saved on your device. Once you tap on edit you will see the other options available (the ones shown in the screenshot I shared but in the app). Still you can check the article linked in my previous post.
I'll be around!
01-12-2019 10:35
01-12-2019 10:35
I have a Fitbit versa and having trouble figuring out what excerise to choose on the watch to calculate on the dash board correctly. Examples: spinning, stair stepper, elliptical what do I choose on the watch that will coincide to the dash board? Thanks
