06-01-2019 03:02
06-01-2019 03:02
Hi
My versa fastener clip (the little loop thing that keeps the strap from flapping around when fastened) is broken. Is there anywhere in the UK I can get a new one instead of buying a new strap?
TIA
06-01-2019 04:29
06-01-2019 04:29
@Rachgre The fastener clips are not sold separately by Fitbit. You might be able to find them online, maybe try Amazon? Otherwise, bands on Amazon aren't expensive. You're best bet is probably just to buy a new band from a third-party on Amazon. Good luck!
