01-19-2019 16:02 - edited 01-19-2019 16:04
I have been using Fitbit Pay successfully on my Versa for several months. Recently, an increasing portion of readers in shops are giving me an error -- "multiple cards presented" today, not sure if it it was the same message on other occasions. -- Is there something wrong with my watch, or have I just hit a string of dodgy NFC readers? If something is wrong with the watch, is it a hardware problem, firmware on the watch, or something to do with the iPhone app?
 Best Answer01-20-2019 13:55
                              01-20-2019 13:55
@Peter_the_SBAM next time you're paying, make sure to close Fitbit app entirely, reboot Versa and then pay. Do not open Fitbit app after rebooting the tracker and before you pay.
01-19-2019 19:50
                              01-19-2019 19:50
May I ask what the problem is @Peter_the_SBAM. Your title says declined but your message says that multiple cards where submitted. These are unrelated different messages. Do you have multiple cards installed on the Versa?
01-20-2019 13:33 - edited 01-20-2019 13:34
Hi @Rich_Laue. Maybe I wasn't clear. Yes, I have two cards loaded on my watch, and when I try to pay with the watch, the reader in the store behaves as if I'm holding two cards against the reader, instead of one. Another thing to add is that, in the past, the watch would ask me to actively select the card I wanted by pushing on it with my finger, whereas now it doesn't seem to.
                              01-20-2019 13:55
01-20-2019 14:24
01-20-2019 14:24
Thanks @Marrrmaduke. When you say to "close the Fitbit app entirely", I'm presuming you mean the App on my iPhone? On many occasions, the phone is km away. I presume it doesn't matter then. Many thanks for the suggestion. Will try it.
 Best Answer01-20-2019 22:05
                              01-20-2019 22:05
I continually get a card read error
01-21-2019 12:49
                              01-21-2019 12:49
@Peter_the_SBAM yeap the app. Reboot Versa and try paying.
@Rich_Laue this trick seems to work for some iPhone users. You're on droid. Haven't tested it myself. Have you tried reinstalling the app?
01-21-2019 13:30
01-21-2019 13:30
Thanks @Marrrmaduke. Great advice. I rebooted and paid successfully at a store yesterday. Will try again on a reader that I know failed before, but that will have to wait until the weekend.
 Best Answer01-22-2019 12:37
                              01-22-2019 12:37
@Peter_the_SBAM awesome. Just remember that you have to close the app and reboot Versa each time... 😑
01-27-2019 17:44
01-27-2019 17:44
Dear Marrrmaduke,
Thanks for this solution - not exactly elegant, but it does fix the problem, and avoids being caught without funds!
 Best Answer01-28-2019 16:40
                              01-28-2019 16:40
@Peter_the_SBAM I'm glad! let's hope it gets addressed with an update. Enjoy your tracker! 😊👍🏻
01-28-2019 17:35
01-28-2019 17:35
Hi, when your phone is one km away form your Versa, you're way out of reach of the BT range and also WiFi range.
12-08-2021 11:53
12-08-2021 11:53
Close the App and reboot Versa FOR EACH PURCHASE?? That would be ridiculous.
I've been using Fitbit Pay off & on for a couple years & only a few times rebooted just because it's an electronic device.
If that needs to be the case FOR EACH PURCHASE, I'll delete Fitbit Pay... Not worth that much trouble!
12-08-2021 18:18
                              12-08-2021 18:18
Your phone dies not need to be anywhere near your tracker for fitbit pay. The phone is not even used during a purchase.
If you find your being declined, call your bank and ask them.
 Best Answer12-09-2021 00:20
12-09-2021 00:20
12-09-2021 03:47
                              12-09-2021 03:47
Next step I would contact Fitbit.
If it shows as declined, and the bank has no record, it may be worth trying a
reboot of the Versa.
12-09-2021 21:26
12-09-2021 21:26
