Hi there @Bobbyboy69, welcome to the Community Forums. I'm sorry for the late response.
While reading your post I was wondering if below the red X there's a message saying "Data not cleared, sync & try again"? If so, this usually happens when you performed a factory reset without before unpairing the Fitbit. Usually you should unpair your Versa, forget Bluetooth and perform the factory reset. To solve this issue, try these steps in the following order:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Give this a go and let me know the outcome.
