06-07-2019
13:39
12:15
DavideFitbit
06-07-2019
13:39
12:15
DavideFitbit
My Fitbit Versa has stopped working, it will not switch on,
I would try restarting the fitbit. This does no harm and can sort out all sorts of issues. On the Versa you do this by pressing and holding the back and bottom buttons until you see the Fitbit logo on the screen.
If that doesn't work then I suggest you contact customer support via contact.fitbit.com If they can't fix it then they can check your warranty status and advise on your options.
