06-25-2020
18:53
13:28
LizzyFitbit
06-25-2020
18:53
13:28
LizzyFitbit
My bpm is not working. I’ve tried turning it off and on in settings, resetting and cleaning the back with alcohol. Nothing worked. The lights on the back are not lit up as they were before. Help please
Moderator Edit: Clarified subject and label
06-28-2020 23:25
06-28-2020 23:25
Hi Fitbit Community I wonder if you could help me?
My bpm won't calculate. it is just blank
--BPM - is what is displayed.
I've cleaned the sensor, shut it down restarted & tried factory reset numerous times & its still not working.
The green light on the back is shining to show that its working.
Other than this the Fitbit works perfectly fine.
Tried browsing all the FAQ and help documents online, Nothing helps.
Please help me get past this issue.
Best Answer06-30-2020 07:35
06-30-2020 07:35
I've followed all of the instructions and reset the watch numerous times. The heart rate monitor is still not working. It was all set up yesterday and still isn't working. Help please!!! Becoming incredibly frustrated with my first ever fitbit!!
07-05-2020 11:55
07-05-2020 11:55
usually keep my versa topped up, but after a full discharge and recharge cycle, HR LED's no longer activate. tried enabling/disabling HR, and i'm going to try a few reset cycles (PITA).
i've learned from past fitbit models that a discharge can be a crap shoot (same thing pretty much killed my OG flex and my charge 2), but a) sometimes it is unavoidable, and b) i would hope that devices would have improved.
bummer!
I'll update if i figure out a way to resuscitate it.
07-06-2020 13:54
07-06-2020 13:54
Hi everyone. Welcome to the forums. It's great to have you here and I'm sorry for the delayed response.
@Wayvon and @Pparkale, thanks for troubleshooting your watches and sharing more details about its behavior. You did a good job and because the heart rate sensor is still not working, I went ahead to contact our Support team and I was told that you already have a case created with them. It seems they're providing you with assistance, so make sure to keep an open communication with them.
@KirstyWT and @tphi, thanks for bringing this to my attention, as well for the steps tried. I see where you're coming from and I'm sorry that the heart rate sensor stopped working. Even though you've tried troubleshooting your watches, please give one last try to the following steps:
I'll be around, let me know the outcome.
07-07-2020 07:09
07-07-2020 07:09
Thank you for the additional tip. I had already tried all of the other suggestions mentioned by others - turning the heart rate function off and on, restarting, shutting down. I just tried your tip hoping for success, but alas, it still doesn’t work. What now?
07-07-2020 07:30
07-07-2020 07:30
Please count me in on this thread. I’ve tried everything as well. No lights on the back, no heart rate tracking. So frustrated.
07-07-2020 08:26
07-07-2020 08:26
I too am having this issue. I’ve rebooted, and did most all of the other steps as well. No green light on back and now not recording steps...
07-07-2020 09:06
07-07-2020 09:06
I just started experiencing this yesterday, as well.
I have tried resetting the Fitbit. I have let the battery die and completely recharged it. I have tried the hard reset. I've tried resetting my phone and reinstalling the Fitbit app. I tried the setting option of turning off my heart rate info and turning it back on. I've tried multiple combinations of all of these steps.
Yesterday, my BPM was frozen on 58, which I knew wasn't correct because I was out in 95 degree heat, helping a friend move. When i reset it this morning, it became completely blank. There is no light on the back sensor, at any point since I've tried troubleshooting.
Thank you for any assistance you can provide. I've had the Fitbit for just over 1 year.
07-07-2020 09:18
07-07-2020 09:18
Hi, followed your instructions but my heart rate monitor is still not working. It just says 'null'.....arghhhh! Help please!!
07-08-2020 01:37
07-08-2020 01:37
Same problem here. Since yesterday no hart rate. (After a swim 🤔) Tried everything of the suggestions. Last option: rebooting, nothing changed. Please help?!
Best Answer07-08-2020 04:21
07-08-2020 04:21
Go to settings on Versa, turn heart rate to “off”, go to app, sync Versa to app, go back to settings, turn heart rate to “on”, then sync again. See if that works?
I’d literally tried every single fix, and the above got my light going, but still wasn’t registering heart rate.
I have about 4 months left of my warranty so I contacted customer service and after a long troubleshooting with them, I’m being sent a new unit.
Happy with the way FitBit handled the situation, not happy that after less than a year this happened. Seems I’m not the only one either, which is sad to see...
Best Answer07-08-2020 05:06
07-08-2020 05:06
Tried everything, now versa is shut down completely! Can't charge, can't restart! What now??
Best Answer07-08-2020 07:19
07-08-2020 07:19
I have the BPM not showing problem also, and just noticed that the back of my versa second rectangle is constant green and looks to be missing the small clear cover for the light/sensor. Anyone encounter this?
Best Answer07-08-2020 08:19
07-08-2020 08:19
I have tried all options noted here and others read elsewhere! Latest thing is that it is not counting steps. Mine is only 1yr old! Mine was a gift and my husband doesn’t remember if he got the warranty. Help!!!
Best Answer07-08-2020 09:00
07-08-2020 09:00
Best Answer07-10-2020 16:32
07-10-2020 16:32
Hi everyone. It's good to see you participating in the forums and welcome to our new members.
@tynlynne, @klcmspt, @JeremyThompson, @Kimtje and @MEP22, thanks for the information provided as well for the time taken to troubleshoot your watch. Because the heart rate sensor is still not working, I've gone ahead and requested a case on your behalf so you can receive further assistance. Please note that due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you soon.
@KatieA1229 and @Lornaclarke69, thanks for sharing your thoughts about this situation and for the steps tried on your own. I've been informed by our Support team that your cases are on their hands and they'll continue working with you via email.
Feel free to let me know if you need anything else.
12-09-2021 16:58
12-09-2021 16:58
My husband has done everything they have listed as well as what your article shows.
Heart rate and nightly score still isn’t working after a week of trying. He may not replaced it cause he is so over his Versa 2
12-14-2021 17:27
12-14-2021 17:27
Hi @Jholt7379. It's good to see you here.
Thanks for joining this thread, and for every troubleshooting step tried on your own. I understand where you're coming from and because the issue with your Versa 2 persists, I'd recommend contacting our Support team so they can evaluate your options and see what can be done to bring you back on track. They're available via chat and phone, just click here to get connected with them.
Have a good day.
