01-15-2019
22:16
07:57
MarcoGFitbit
01-15-2019
22:16
07:57
MarcoGFitbit
have trouble syncing,does the device have to be in the cradle or just close to it?dashboard message tells me I could be connected to another device,I am only on windows 10
Best Answer01-16-2019 08:00
01-16-2019 08:00
Hello @wireman, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. Please note that it's not necessary for your Versa to be plugged in and charging while you sync it. However, I would like to suggest you to restart your Versa by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen then try to sync it. If you're sitll having trouble syncing your Versa, please check the following steps:
If your device still won't sync, try these steps:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
Best Answer01-23-2019 14:11
01-23-2019 14:11
Useful info, but still trouble syncing,(1) does the watch have to be in the cradle,(2) window keeps wanting to pair,when this is done syncing is worse,(2) have an older HR Charge on an I-PAD have no worries with that at all keeps wifes stats OK.
