11-07-2018
03:09
08:02
AlejandraFitbit
11-07-2018
03:09
08:02
AlejandraFitbit
I can't get any notifications from my Android on my Versa, any help?
Best Answer11-07-2018 04:20 - edited 11-07-2018 04:34
Hi, @Iman2018, have you checked that your phone is on the list of supported devices?
I would recommend opening your Fitbit app and select your Versa. On the next screen scroll to the bottom and make sure Always Connected and Keep Alive Widget are switched on.
Next select Notifications (which is a little higher up on the same screen). On the Notifications section if they are turned on, and you still aren't getting notifications then click the three dots top right and choose "Disable notifications"
Next go to your phone's Bluetooth settings, and if your Versa is showing as "paired" choose "unpair".
Then, return to your Fitbit app and turn your call and other notifications back on. (That will force a re-pair). Finally, click the 3 dots on the top right of the notifications screen in the Fitbit app and choose "Send a text call notification". Hopefully that will re-set up notifications.
I have to admit that my Versa loses notifications quite often, so on my Android phone I have to go through this procedure pretty regularly, and sometimes I need to repeat the procedure a couple of times before the notifications start coming through again.
Edited to add: you may also need to restart your Versa and also toggle Bluetooth off on your phone, wait 10 seconds, and toggle it back on. By going through these steps I do eventually get my notifications back...
11-11-2018
08:03
08:02
11-11-2018
08:03
08:02
