10-10-2018
13:49
05:08
AlejandraFitbit
10-10-2018
13:49
05:08
AlejandraFitbit
My Fitbit hasn't synced since the 2nd of Oct, it says its on all day sync but its just not working. Also the app says my batteries low even when its fully charged.
The battery level on the app shows the level when it last synced so once you get the syncing going again that should sort itself out.
The usual things to try when you get syncing issues are:
10-12-2018
05:09
08:02
10-12-2018
05:09
08:02
Welcome to the Forums @Mrswhyte18 and @SteveH thanks for stopping by.
I would like to know if you keep having issues syncing your Versa? Have the instructions provided by our friend worked?
Hope to hear from you soon. ![]()
Best AnswerI just received my Fitbit Versa yesterday. It synced when I set it up but has not synced since. I have restarted the phone and the device multiple times, I have turned the bluetooth on and off several times. I uninstalled the app and reinstalled it. I can't get my Versa to sync.
Same here i have followed instructions and it still isnt working
