06-21-2018
22:48
11:54
RobertoME
06-21-2018
22:48
11:54
RobertoME
I entered one of my cards into Wallet which requires me to unlock my watch every time I put it back on.
This worked fine for a few weeks but now I can’t swipe up or down on my watch without having to enter thevpun code and then it doesn’t unlock my watch anyway.
Ive tried to change my settings for the pin code to only be required when I use my card, but it won’t let me.
anyone know how I can fix this.
Moderator Edit: Updated Subject For Clarity.
11:53
09:09
06-25-2018
11:53
09:09
Hello @reewil, good to see you around in the Fitbit Community! My apologies for the late response and I'm wondering how it goes? Is the Versa still requiring to enter the pin everytime you want to use it?
You mentioned that you tried to change the settings, but it won't let you. I wondering if you are not able for an specific reason, or the change does not affect the behavior of the Versa?
Perhaps performing a restart will do the trick: How do I restart my Fitbit device?
For more information regarding the pin code, refer to this help article: How do I use the device lock on my Fitbit watch?
Hope this helps and let me know how it goes.
Best Answer06-25-2018 13:31
06-25-2018 13:31
