02-27-2019 03:52
02-27-2019 03:52
Hi
I have a Fitbit Versa and it won't keep the time. 3 times yesterday I looked at my watch and the time was wrong. As soon as you open the Fitbit app on my phone (Moto g6 play) it syncs and corrects the problem.
I have checked the time zone and that's all correct. (From a previous post)
I am nervous about doing a factory reset as some have said this has broken the watch.
Anyone got any ideas on how to fix it?
02-28-2019 15:51
02-28-2019 15:51
Hi @SunsetRunner
So I restarted it and it came back on now problem. However.....during the night it switched itself off so I turned it back on. At 9am-ish it turned it's self off again but I didn't realise until some time later so I turned it back on using the left button and the bottom right hand button but this time it took several attempts to turn on, eventually it came on but as soon as the screen went black that was it. Off again.
So I put it in the charger and it registered 0% on the batt. I left it charging all afternoon. When I came back to at 5pm it still wouldn't turn on. Eventually I managed to get the screen to come on by unplugging/plugging the charger back in so I did a factory reset. It went off while reinstalling now I can't get it to turn on again.
Any ideas??
02-27-2019 05:28
02-27-2019 05:28
Hi @Bex_chiz . Try going into Account from your Fitbit app. Change to All Day Sync. That may help.
Best Answer02-27-2019 10:22 - edited 02-27-2019 10:22
Hi @SunsetRunner
I already checked and it is set to all day sync. I'm gonna give the reboot a go (re: your comment in another thread) see if that sorts it out.
Thanks for your help
02-28-2019 15:51
02-28-2019 15:51
Hi @SunsetRunner
Any ideas??
03-07-2019 03:46
03-07-2019 03:46
Please note to anyone reading this. I've had no solution to the problem. I clicked the accepted solution by accident and now I can't undo it .
Best Answer01-09-2020 20:27
01-09-2020 20:27
I tried this too and my Fitbit is set to all day syncing. It does not stop the problem of loosing time.
Best Answer01-09-2020 23:48
01-09-2020 23:48
Best Answer09-22-2021 15:21
09-22-2021 15:21
Mine is loosing time too any answers???
