02-06-2021 12:36
02-06-2021 12:36
After buying this almost 2 years ago battery life is terrible doesn't last but 3 days and I have everything off and I'm injured stuck sitting at home. Doesn't want to sync, doesn't want to connect to Bluetooth. What a waste of money. This is a replacement as the first one stopped working. I bought 2 of these and my girlfriends doesn't sync, time is way off ,will not connect to Bluetooth. So we are switching to a real company in Apple
Best Answer02-07-2021 01:02
02-07-2021 01:02
Seems like this is a common issue. Possibly due to a recent update, if it was working before.
In which case its probably best to inform Fitbit Support directly. They may be able to help you.
02-07-2021 01:02
Best Answer02-07-2021 11:25
02-07-2021 11:25
Pointless as they will say do a factory reset and last time I did that it didn't work anymore and had to be replaced. Sad is all I normally last 5 days and when I wasn't injured I walked 20k steps a day. Now I don't do anything an in less then 3 days its dead and yes I use the proper charging cable
02-10-2021 08:13
02-10-2021 08:13
Not best answer at all
