12-27-2019
04:40
09:36
AlvaroFitbit
12-27-2019
04:40
09:36
AlvaroFitbit
Why is it that the Samsung J7 Refine is not listed as a compatible device for the Fitbit Versa Lite?
I currently have a Fitbit Flex 2 and it is compatible and I have had no issues.
Will the J7 be added soon?
09:38
12:08
01-02-2020
09:38
12:08
@Kelmiller Welcome! It's good that the community is growing! Sorry for the delay in my reply.
Let me help you with your compatiblity inquiry between your phone and the Versa lite. As you said your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You said it yourself, you are currently using your phone with the Flex 2 without any issues. If you buy the Versa lite you can try it out and see how it behaves with your phone. If you have any issues you can try the following:
Let me know how it goes.
Best AnswerYes I do have a Fitbit 2 but I am unable to use all the features with my Samsung J7 as I did with my previous Samsung phone that is listed on the compatible list. I dont want to spend the money for one and only be able to use a handful of the many features.
