Versa lite step count not accurate
Even while traveling in a car  steps are being considered. How to fix it.
1 REPLY 1
@Katoch, welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your step count. Your device will detect the movement on your arm and translate that movement into steps. There are situations in which your arm may move but you won't be actually walking. For example, this may happen when you are playing the drums, burping a baby or clapping. It can also happen when driving. You can negate these steps by logging a driving activity. You can try wearing your device on your non dominant hand but select that hand as dominant on the device’s settings to make it less sensitive to movement.
Let me know how it goes.
Alvaro | Community Moderator
