12-15-2020
11:17
12:05
12-15-2020
11:17
12:05
I have contacted support numerous times about the issue. Every day my fitbit looses time and will stay connected to bluetooth. I have had this for 2 years and have not had this problem until 2 months ago. I am using the the same phone, galaxy note 9. I have updated, deleted and reinstalled, shut done, reset. You name it. I can't even rely on the fitbit for my alarm. By the morning there is a 20 min time difference with the phone in the same room. I'm at my wits end and thinking about changing to the galaxy watch
12-15-2020 12:07 - edited 01-10-2024 10:40
Hello there @Mfazio42, welcome to the Community Forums. Thanks for trying to troubleshoot this situation prior to posting here.
Besides the steps you've done, please try the following:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Please let me know if you continue having syncing difficulties after paring your watch.
Best Answer12-15-2020 14:07
12-15-2020 14:07
can someone PLEASE tell me HOW to contact support??? nothing here helps me and my fitbit is my watch--it is 1 1/2 hours behind all of a sudden after charging it as I usually do. Now I have no watch and this thing is only a year old--had similar problem in Nov. but got it back to working after 12 hours of fooling with it. I WANT THIS REPLACED UNDER WARRANTY.....don't have time to spend trying to make it work---PLEASE give me a phone number where I can speak to someone about replacing my versa2
12-15-2020 16:05
12-15-2020 16:05
Those steps were all done, more than once, with the several times I contacted support and then shortly after no bluetooth connect ion and it starts loosing time. Generally every hour I loose about 2-4 minutes every hour.
Best Answer12-15-2020 16:07
12-15-2020 16:07
Here is number I used 1-877-623-4997
Best Answer12-15-2020 22:51
12-15-2020 22:51
That is the exact same problem that I have. It's really irritating because support just gives me the links as advice - I'm beginning to think a different brand might be the way to go.
