03-13-2019 16:07
03-13-2019 16:07
I used to use charge 2 and I could easily see steps translate to miles....how can I do with versa????
03-14-2019 08:03
03-14-2019 08:03
@Pennys37 Can you please elaborate? Steps translate into distance the same way on all fitbit devices. If you mean, you would like to see your stats on the device itself, you can access them via Today app. Just swipe up on the main screen of your Versa to open Today app. The core stats section (i.e. steps, distance, floors, calories, etc.) is usually the first one. Swipe left to go through various stats. If you would like to see the distance on the main screen of Versa itself (as a clockface), you will need to find a clockface that displays that particular stat and install it.
03-14-2019 08:03
03-14-2019 08:03
03-14-2019 13:30
03-14-2019 13:30
You answered perfectly and thoroughly and completely "solved" my problem
