02-25-2020 23:50
02-25-2020 23:50
Hi. I've had a Versa since May 2018 - and had a lot of issues syncing to my Samsung S10. It has been on and off the entire time I've had the watch - and I am used to installing and uninstalling the watch almost weekly.
After finally managing to install the latest update it worked great for a while, but right now there is no connectivity. I have attempted to connect to my Android phone and it cannot find the watch.
I have tried re-starting the watch. Uninstalling the app on my phone. Re-starting the phone. In the past it has helped to unpair the watch and add it again - but this time it does not find the watch.
In Android, I cannot see the watch in my Bluetooth list. When trying to find the device in the Android app it says "Is your Versa powered on?". And it is. The previous days it even got to "Found it!" - but then the next step failed.
I was able to sync it to Windows 10 PC.
Thanks for any help.
02-26-2020 06:18
02-26-2020 06:18
@LineRyan, welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it won't connect or sync with your phone. I appreciate the time spent trying to get this issue resolved before contacting our forums.
I'd like you to try the troubleshooting steps that are listed in this help article. This article contains steps that you already tried but you can skip them and proceed with the rest. After trying these steps, monitor your watch and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer02-29-2020 01:23
02-29-2020 01:23
No. Nothing is working. The app says No device connected. Since I got it I have had trouble connecting to WiFi in the app as well and cannot open wifi settings, it is just loading. The screen prompt Attempting to link when opening the app is also just loading, and never finishes. I can still not find thw device in my Bluetooth search either.
Best Answer03-03-2020 08:42
03-03-2020 08:42
@LineRyan, I apologize for the delayed response. However, thank you for trying the recommended troubleshooting steps.
Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any question arises.
Best Answer03-03-2020 16:15
03-03-2020 16:15
I'm unable to pair my Versa since the most recent Samsung OS update. The phone seems to detect the Versa but will not pair with it. Have tried everything in the Help article with no luck 😞
