12-28-2018
19:05
11:36
DavideFitbit
12-28-2018
19:05
11:36
DavideFitbit
Hi community
This Morning the screen was gone..gray looking. Now its nit charging. Help pl
@Jeca When was the last sync? Does it still connect to the phone (can be seen by Fitbit mobile app)? Wipe/rub the charging contacts with a bit of alcohol and plug for charging by using USB on your computer (I'm assuming you have tried wall outlet). Let it charge for several hours (let's say 4), then press and hold the left and bottom right buttons until Fitbit logo flashes. If this does not help, try performing a 3-button factory reset:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
If you're successful with factory reset, please remember to remove Versa from your Fitbit account (in your Fitbit mobile app) and Paired Devices list in your phone Bluetooth settings as you will have to set it up again (add as a new device).
