Hi @Josslongman Welcome to the Community. Have a go at giving your Versa's charging contacts a Clean then try recharging. If this doesn't help then the way forward will be to contact Customer Support for some further assistance.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
11:18
11:02
03-25-2019
11:18
11:02
A warm welcome to the Community @Josslongman and @Tony.r thanks for the input.
I appreciate all the efforts in trying to fix this battery issue by yourself and was able to see here that our friend @Tony.r provided some instructions in order to fix this battery problem. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. ![]()
