01-29-2020 17:18
01-29-2020 17:18
My versa hasn’t been counting floors for a few weeks now. I’ve done the reset thing by holding down the butting for 10 seconds several times but it still isn’t counting. Any other ideas?
01-31-2020 17:18
01-31-2020 17:18
@Ajamu Do you have a Versa or Versa Lite? You tagged your post "Versa Lite". If you have a Versa Lite, it does not track floors.
01-30-2020 00:34
01-30-2020 00:34
Your fitbit tracks floors by measuring changes in air pressure through a small hole in the back of the fitbit. If this hole becomes blocked then it can cause this problem.
Try cleaning it with, for example, an old toothbrush or a can of compressed air. Don't poke anything into the hole though as this can cause more problems.
01-31-2020 17:18
01-31-2020 17:18
01-31-2020 17:21
01-31-2020 17:21
02-05-2020 02:42
02-05-2020 02:42
@Ajamu you are very welcome .
