11-20-2018
18:01
07:18
MarcoGFitbit
11-20-2018
18:01
07:18
MarcoGFitbit
My versa is not notifying me with phone calls or messages. I have a galaxy Note 8
Best Answer11-20-2018 20:02
11-20-2018 20:02
Check that 'Show on Lock Screen' is enabled in your phones settings app.
Helen | Western Australia
11-20-2018 20:48
11-20-2018 20:48
@Joni77 also check the notifications are on on your versa. just press and hold the left button.
11-21-2018 05:58
11-21-2018 05:58
Thank you I will
Best Answer11-21-2018 07:25
11-21-2018 07:25
Hello @Joni77, have a warm welcome to the Fitbit Community, it's great to have you on board. It's nice to see you around @Marrrmaduke and @NellyG, thanks for all your help. ![]()
@Joni77, I appreciate your participation in the Forums and for sharing your experience with us. If you have already checked the troubleshooting steps provided by @Marrrmaduke and @NellyG and you're still having trouble receiving Notifications, please try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
11-21-2018 17:35
11-21-2018 17:35
Best Answer11-21-2018 17:55
11-21-2018 17:55
@Joni77 yes. It should be ON.
Best Answer11-21-2018 20:16
11-21-2018 20:16
Best Answer11-22-2018 07:13
11-22-2018 07:13
Hello @Joni77 and @Marrrmaduke, I hope you're doing well, thanks for taking the time to reply. ![]()
@Joni77, as @Marrrmaduke mentioed, the Fitbit Notification service should be on in order for your Versa to receive Notifications from your phone.
Give it a try and keep us updated, we'll be happy to help.
11-22-2018 09:34
11-22-2018 09:34
@Joni77 no, it won't. 😊
Best Answer01-10-2019 10:16
01-10-2019 10:16
Has anyone tried using their note 8 phone in power saving mode? I am not getting notifications when in this mode on the Versa. However I did when I had the Blaze? Anyone know why this would be?
Best Answer01-10-2019 14:31
01-10-2019 14:31
@Joedirt07 it's probably optimizing Fitbit app and Bluetooth battery usage. Go to system battery settings and turn off the optimization for Fitbit app.
Best Answer01-11-2019 06:18
01-11-2019 06:18
I'm not sure how to see that for certain while in Maximum Power Saving mode. However, while in the standard mode I noticed that the Fitbit app it one of the few apps that is not being optimized. So I don't think this resolves the issue.
Best Answer01-11-2019 06:33 - edited 01-11-2019 06:34
@Joedirt07 The fact that in the regular mode the app is not being optimized does not mean it won't get killed when the battery saver is ON. Actually, Android will wipe any processes that substantially utilize RAM or/and CPU (such as Fitbit app). On top of that Android will optimize your Bluetooth radio as well. The same happens to Versa as well that will limit its functionality (sync, HR monitoring, notifications) when the battery is critically low. I am afraid you might have to simply turn off battery saver or plug the charger.
Best Answer01-11-2019 08:16
01-11-2019 08:16
Yeah I figured that would be the case. I'm just really confused on how this connection works differently than the Blaze. I think that's what doesn't make sense to me if it's the same app and connected via Bluetooth right?
Best Answer01-11-2019 10:30
01-11-2019 10:30
I have to toggle my BT off and then on again every morning to get them to work but then they generally do for most the day.
Best Answer07-12-2019 07:33
07-12-2019 07:33
Mine has been the same for 2 weeks now.. Nothing I've tried works... The app keeps telling me that I need to restart my phone... I've done this countless times and it hasn't helped... the only notification I'm getting on the watch is to move... 😤
Best Answer07-12-2019 07:42
07-12-2019 07:42
Thank you!! Finally!! This seems to have worked!! 😊
Best Answer06-27-2020 15:50
06-27-2020 15:50
I am having this issue and I cannot find a solution. I've searched through everything on the help sections for fit bit and I've read through these forums and I've looked at all my settings in the phone, in the app, and on the watch. I've refreshed and reset everything a ridiculous number of times. I just got this versa and I'm really sad that I can't get the notifications to work. Anyone have any ideas that I may have missed?
