09-18-2018
14:16
09:33
MarcoGFitbit
09-18-2018
14:16
09:33
MarcoGFitbit
So happy with my Versa, beautifull and a lot of stats, so disapointed when it dosn’t work, syncing doesn’t ”work, updatws don’t come trugh, so very disapointed!😢😢
Best Answer09-18-2018 14:26
09-18-2018 14:26
What are the specs of your phone? Without those, we won't be able to help you as much as we would like to.
one cruise ship at a time!
Best Answer09-19-2018 09:37
09-19-2018 09:37
Hello @Liesling68, thanks for joining the Fitbit Community, it's great to have you on board. It's nice to see you too @DramaQueenDiva, thanks for all your help. ![]()
@Liesling68, I appreciate you have taken the time to share your experience with your Versa. As @DramaQueenDiva mentioned, we will need to have more information about your issue, including the model of the phone you're currently using to sync the Versa.
In the meantime, if you're having trouble updating the Versa, that's probably why it's not syncing correctly, in which case I would like to suggest you that before you begin the firmware update, make sure your watch is plugged into the charger and in range of your Wi-Fi network during the update. For best results, use your home or work Wi-Fi network. If you've never connected your watch to WiFi, see How do I connect my Fitbit watch to Wi-Fi?. If your Versa is having trouble updating with WiFi, please try the following:
If the update fails, restart your mobile device and try to update again. If your Versa can't update over WiFi follow the on-screen instructions in the Fitbit app to update your watch over Bluetooth instead. Note that firmware updates over Bluetooth may take significantly longer to complete. If the Versa is having trouble updating through Bluetooth try the following:
Now, if your Versa gets updated and it's still not syncing correctly, please try the following:
If your device still won't sync, try these steps:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
