Best AnswerI think you will also need to go into the fitbit app and remove the Versa from your account there too. Then try setting it up again.
Best AnswerDidn't work and now I can't reconnect it to my account...
Best AnswerHave you checked that no other devices are trying to communicate with the watch via Bluetooth? If anything is interfering or the watch is trying to connect to another device it can cause communication issues. The best thing to do is to turn off any other Bluetooth device while you are trying to set it up again.
Best AnswerNothing else is trying to connect and I often have multiple Bluetooth connections running at the same time (I.e. Car and Versa) with no issues.
Best AnswerThere could be a fault with the watch. At this point you may wish to contact customer support.
Best AnswerA few of points I have
Steps that can help, most you have tried
Let us know what phone you have. We need to fix the sync issue before we will be able to reconnect the Versa to your account.
