Fitbit pay
I work as a cashier and I was wondering if I should use Fitbit pay or if it will start paying for customers purchases! Is it safe? Does it only make a transaction when the wallet app is open?
6 REPLIES 6
Yes it will be fine.
Fitbit pay is only activated when you press and hold the left button and you virtual card is displayed on the screen. Any other state the card reader will just reject it or throw up an error.
If you want to be certain for peace of mind. Try paying for something with Fitbit pay but don't activate it by long pressing the left button to see what happens.
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
Unless you are in Australia!  Apparently you do not have to press and hold the button there.  However, I expect you would still need to put your Fitbit in close proximity to the payment device.
More info here.
More info here.
Yes that's correct, I would imagine it still needs to be enabled initially by a pin every 24hrs or if you take the watch off?
Nathan | UK
@N8teGee, yes, I believe everything else is the same.
It's strange that it's only Australia that has this set up. It would leave the device vulnerable to skimming.
Nathan | UK
It probably has something to do with Regulations in Australia
