08-23-2018
21:12
09:54
MarcoGFitbit
08-23-2018
21:12
09:54
MarcoGFitbit
I recently got the fit bit versa and for the first few days it was working perfectly. I absolutely loved the GPS for runs, texts alert, sleep tracking. Then all of a sudden it would not sync with the app on my phone. So far I've had the Versa for 10 days....and its been frustrating me to no end for half that time.
I deleted the fit bit app and reinstalled it
Turned my WiFi on/off
Removed the Versa from my Bluetooth (forgot device)
Reset the Versa 3 times
Turned my iphone off/on
Removed the device from the fitbit app, but now can not get it to add back on
My phone finds the Versa, but it gets stuck on "Connecting to Tracker" I have been tinkering around with this for about two hours now, and no luck
Is this something that is occurring often with others? Am I doing something wrong? I might just have to take this item back and return it... Sadly, because I really enjoyed it for the time it worked.
I also read if your car has bluetooth it can throw the Versa off
09-27-2018
12:41
09:57
MarcoGFitbit
09-27-2018
12:41
09:57
MarcoGFitbit
Of course it was through the app. Have no idea how to do it otherwise
Chris Desser
Sent from my iPhone--please forgive iTypos
Moderator Edit: Removed Personal Information.
Best Answer09-27-2018 12:44
09-27-2018 12:44
You say your phone finds the tracker, using the app to sync, there is no option for the phone to look for the tracker, therefore I'm confused..
But has Fitbit support gotten back to you? I'm not sure which if the several ways available was used to contact support.
12:52
09:57
MarcoGFitbit
09-27-2018
12:52
09:57
MarcoGFitbit
I have. It heard from Fitbit. The only phone shows the status of the connectivity as it is happening. In fact you are instructed to have the phone beat the charging cradle. Instructions show up in the phone.. Before the process continues you have to agree to their disclaimer or whatever you would call it. I have no idea how to connect the device other than through the Fitbit app on my iPhone
Chris Desser
Best Answer10-04-2018 10:01 - edited 10-04-2018 10:46
Hello everyone, I hope you're doing well.![]()
I appreciate your participation in the Forums, for sharing your experience with us and for letting us know about the troubleshooting steps you've tried so far in hopes to resolve this issue. I understand some of you have already contacted our Support Team and I would like to encourage you to keep troubleshooting with them as they will be able to provide you more options. For those of you who haven't contacted our Support Team, I would like to gather some information from you so we can determine what we should do next, please reply with much information as you can:
Thanks for your patience and understanding, I'll be waiting to hear from you, have a great day.
Best Answer10-04-2018 11:00
10-04-2018 11:00
10-04-2018 22:26
10-04-2018 22:26
Yes the Versa is having issues with the sync. It is connected to the App but will not update till we reset the Versa device and reinstall the App.
this is happened thrice.
i recommend to stay away from Versa not a good device to buy.
10-05-2018 15:43
10-05-2018 15:43
I reinstalled Fitbit App from Google Play store one more time and now my Versa works fine. I hope you have the same experience!!
16:23
08:24
AndreaFitbit
10-05-2018
16:23
08:24
AndreaFitbit
Thanks!
Chris Desser
Moderator edit: removed personal information.
Best Answer10-05-2018 16:52
10-05-2018 16:52
Best Answer10-05-2018 23:56
10-05-2018 23:56
I bought a Versa about a month ago. For the first couple of weeks, it worked great syncing with iOS on my iPhone 7. I noticed about 10 days ago that it quit syncing and was showing zero steps in my app.
I have read read every article I can find. I have uninstalled the Fitbit App, restored the Versa to factory settings numerous times, turned Bluetooth on and off, and everything I can think of, and I can’t seem to fix the issue.
As of today, the Versa would count my steps during the day, and they would show up in the app. Then at midnight, the previous day’s steps go back to zero. There is no sleep log, no steps stored, no calories burned, etc.
So basically, I have a $200 pedometer piece of junk that won’t store ANY data after midnight. I could have bought a $2 pedometer that would have done the same thing.
I’m ready to throw away this piece of garbage and go back to my Alta, which had no syncing problems, but the cheap plastic Alta charger broke 3 different times and I got sick of buying new ones.
Can anybody help?! I know I’m not alone in these syncing issues!
Shame on Fitbit for selling a product with so many bugs that it became unusable! If you are thinking of buying a Versa, save your money and get an Apple Watch instead! Fix these bugs, Fitbit! 🐜 🐛 🕷 🐛 🐜 😡
10-06-2018 00:02
10-06-2018 00:02
I am having the same problem! Bought it a month ago and it worked great. Then it stopped syncing with my app. I have uninstalled, reinstalled, reset to factory, deleted from Bluetooth and reconnected.
Now it will sync with my app during the day and then reset and “forget” previous day’s steps/calories/sleep at midnight. For almost two weeks I have no data in my app.
This is ridiculous and the Versa was a huge waste of money! 😡
Best Answer03-05-2019 17:44
03-05-2019 17:44
The only way that I have found to fix most fitbit issues is to do a factory reset on the watch itself, your app will still store all of your collected information, all you will have to do is redownload the clock face.
Best Answer11-01-2019 17:05
11-01-2019 17:05
having trouble syncing my fit bit versa to my ipad it is not showing up on the fit bit dashboard app and also not showing sleep pattern on watch would appreciate for it to record all steps and calories burnt and sleep pattern and all other things that I bought the watch for because at the moment it is not recording anything as it will not syncing with my ipad
Best Answer11-01-2019 17:07
11-01-2019 17:07
how do I do this and will it do everything when you do this or do as you say have to download watch face and wont this change all of the details on your watch
Best Answer11-02-2019 22:00
11-02-2019 22:00
@cheryl.stanley if you indeed do not see your Versa on your dashboard, it usually means that the Versa is not connected to your fitbit account and will need to be setup through the Add Device.
As for watch faces. No this has nothing to do with any data that may be on the tracker.
