10-28-2018
19:48
07:05
AlejandraFitbit
10-28-2018
19:48
07:05
AlejandraFitbit
I have done everything suggested that deals with not syncing to my phone. My Versa even has the wrong time. Hasn't synced in a month. Very disappointed. What should I try next?
Best Answer10-28-2018 22:49 - edited 10-28-2018 22:49
Don't know what you should try @Tjs_lipping, I'm not sure what model phone that you have our what steps have already been tried.
Make sure the Fitbit app is up to date.
On Android
Turn bluetBlue off/on
Clear the Fitbit's app cache
Restart phone
Restart tracker
Log out/log in
10-29-2018
07:06
04:52
10-29-2018
07:06
04:52
Welcome to the Community @Tjs_lipping and @Rich_Laue thanks for stopping by.
I appreciate all the efforts in trying to fix this issue and recommend taking a look at the help article Why won't my Fitbit device sync? and follow the instructions provide there.
Let me know the outcome. ![]()
10-29-2018 16:50
10-29-2018 16:50
Best Answer11-05-2018 19:17
11-05-2018 19:17
None of it worked is there away to reset the fit bit and start from scratch or should i be looking at how can i return this one and get a new one
Best Answer11-05-2018 20:30
11-05-2018 20:30
@Tjs_lipping you can do a factory reset, but before that is tried I would do an add device. Choose the option to replace the Versa tracker.
Not knowing which phone that your having problems with, I don't know if I can give specific help. Like with Android clearing the Fitbit apps cache, or all cache, shit down the restart the phone and do the same for Versa
