11-17-2018 19:23
11-17-2018 19:23
My Versa is only a few months old. It won’t sync steps, date etc unless i hold left button and bottom right button down simultaneously.
Best Answer11-17-2018 19:41
11-17-2018 19:41
@Lanalawson Sorry to hear that. Has the problem appeared recently? How often does it happen? Also, what is your phone model and OS?
Best Answer11-17-2018 19:59
11-17-2018 19:59
I am having the exact same issue. 😑
Best Answer11-17-2018 20:52
11-17-2018 20:52
@kuhrisduh @Lanalawson Perhaps this thread will be of some help.
Best Answer11-19-2018 10:08
11-19-2018 10:08
Hey guys! @Lanalawson and @kuhrisduh, welcome to the Community!
If you are having syncing inconveniences, as @Marrrmaduke asked, I'd like you to tell me what phone model are you using. Are they compatible devices? In the meantime, you can also try the troubleshooting in this help article: Why won't my Fitbit device sync?
Keep me posted!
Best Answer11-19-2018 14:09
11-19-2018 14:09
My Fit bit stopped syncing with my phone 2 weeks ago. Up until then , not a problem. I've tried all the tricks -uninstall/reinstall, hard reset etc and nothing is working. It will sync with everything else but my phone. I have the HTC u ultra. And both it and the fit bit are on the latest software.
Best Answer11-19-2018 18:13
11-19-2018 18:13
@Deathwishvixen Have you tried forgetting your versa from your phone's Bluetooth settings, followed by restarting both phone and Versa, and forcing the sync within the Fitbit mobile app?
Best Answer11-19-2018 18:16
11-19-2018 18:16
Best Answer11-19-2018 18:25
11-19-2018 18:25
@Deathwishvixen I believe I just replied to your post in other thread. I have a suspicion it might be related to one of the recent Fitbit mobile updates. My advice would be to downgrade to the previous version (2.81) if it was working for you, or to version 2.74 (this build along with 2.81 seems to work best for me). Of course you will have to download android package file and sideload it.
Best Answer11-20-2018 05:54
11-20-2018 05:54
Hey @Deathwishvixen, it is great to see you around more often! I appreciate you have taken the time to try some troubleshooting to make your Versa sync with your HTC U Ultra. Considering that your phone model isn't on the compatible devices list, I'm afraid that you might experience syncing issues even though you didn't experience them in the past. You can go ahead and try the tip that @Marrrmaduke posted above, however is not a guarantee that it'll work. In addition, I'd like you to take a look at all the troubleshooting in this help article: Why won't my Fitbit device sync?
Let me know how it goes!
Best Answer11-26-2018 21:18
11-26-2018 21:18
It has now randomly decided to sync. The only difference is that the screen broke and now syncs perfectly .
Best Answer11-26-2018 21:54
11-26-2018 21:54
@Deathwishvixen what happened to the screen? ☹️
Best Answer11-26-2018 22:01
11-26-2018 22:01
Best Answer11-26-2018 22:04
11-26-2018 22:04
@Deathwishvixen I'm really sorry to hear that. ☹️ I'm assuming the physical damage like that is not covered under warranty? ☹️ is the display still usable/functional? Perhaps a screen protector to secure it a bit? ☹️
Best Answer11-26-2018 22:22
11-26-2018 22:22
I'm having this same issue and it's really starting to infuriate me. It hasn't synced since 19th November yet it's set to all day sync. I have rebooted it and the phone.
My battery life has also reduced. I'm finding I have to charge it more than I was
Best Answer11-26-2018 22:41
11-26-2018 22:41
Best Answer11-26-2018 22:47
11-26-2018 22:47
@Deathwishvixen that's really a bummer. ☹️ Perhaps you could get one of these to help protect the screen a bit? I have one myself and they're quite good.
Best Answer11-26-2018 22:52
11-26-2018 22:52
