12-28-2018 14:31
12-28-2018 14:31
My versa isnt symcing with my phone. Have an new Android and its updated. Bought my versa The other Day and ive had problems with the syncing, both notifications from messages, GPS and data from the watch to the application. I have tried everything, restarts, deleting and adding application again and nothing seems to work!? Anyone who has an idea?
Best Answer12-28-2018 15:30
12-28-2018 15:30
Hi, which device are you using?
Best Answer12-28-2018 23:27
12-28-2018 23:27
Hi! Its a fitbit versa 🙂
Best Answer12-29-2018 02:23
12-29-2018 02:23
Have you checked that your android is supported by fitbit at www.fitbit.com/devices ?
Best Answer12-30-2018 02:37
12-30-2018 02:37
Hi! Yes it is compatible and aupdated 😅
