05-29-2018
17:22
09:43
AlvaroFitbit
05-29-2018
17:22
09:43
AlvaroFitbit
Hi All,
my dashboard is not tracking workouts and physical activity time. Tracks all other stats (steps, stairs, calories, etc). Not syncing at all when i “force” sync. Help!
05-30-2018 09:56
05-30-2018 09:56
@Beauti381 Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your Versa isn't recording your activity. You mention that your steps and other data are being recorded by your Versa. Which activities haven't been recorded by it? How do you track these activities (using the different exercise options on your Versa, via SmartTrack autodetection, manually logging them)?
I look forward to your reply!
05-30-2018 14:17
05-30-2018 14:17
Hi! My phone app is partially syncing to my versa. It will automatically capture my steps, flights, miles, calories, heart rate. The phone app is not capturing my hourly steps, workouts, minutes of physical activity, and my sleep. when I "pull" the screen to sync, it does nothing. I have made sure my iPhone is updated, fitbit app is updated, restarted my phone and fitbit but my sleep and workouts are not syncing, I have to manually put them in. Yesterday, I used FitStar to work out. When doing other workouts, I manually start the workout on the device, as to not have the versa automatically track it. Yesterday, I uninstalled my device from my app and re-connected it and it synced my hourly steps/ FitStar work out but I don't want to have to do that everyday. Thanks in advance.
06-18-2018 09:03
06-18-2018 09:03
@Beauti381 you don't mention which activities aren't being recorded. For how long do you do these activities? Are they supposed to be detected by your Versa (check the SmartTrack article to learn more about activities autodetection)? You mentioned that the previous day you used Fitstar but do you this all the time? Could you share a screenshot of your sleep area on your app (tap the sleep tile and provide a screenshot of this screen)? Are you walking at the time of the reminders to move or are you logging activities during this period?
06-18-2018 10:45
06-18-2018 10:45
I just uninstalled the app and reinstalled. Problem solved. Thank you.
07-03-2018 06:50
07-03-2018 06:50
@Beauti381 happy to hear that you were able to resolve this issue and thank you for posting what you did to correct this as it may help other members in the same situation.
I'll be around!
10-29-2018 20:01
10-29-2018 20:01
I am having the same issue. Sleep has not automatically synced for 2 nights now. And i did the treadmill today and weights, hit play and stop on my versa and it has not synced to the app. Yet my steps, flights and heartrate are fine. I tried to uninstall and reinstall the Fitbit app. Also tried to log out of Fitbit and restart my phone then log back in and nothing is working!! Help!!
01-08-2019 15:30
01-08-2019 15:30
Hello,
I am not sure if I am doing something wrong. When I go to the gym, on the versa watch itself, I click on exercise- then scroll to Workout and click it- then click the arrow at the bottom to start the workout. I do Crossfit so it is a combo of weights and cardio. However. twice now the watch has not tracked my exercise and I have had to log it manually. Am I doing something wrong? I have reset the watch as well as uninstalled and reinstalled the app on my phone.
Please help!
02-14-2019 08:17
02-14-2019 08:17
I’m having the same problem. When I’m done with my workout I press pause and then end the workout. But nothing happens. It doesn’t indicate the active minutes. Still lots of as zero
03-26-2019 12:35
03-26-2019 12:35
Have you found a resolution to this problem? I am manually starting a workout on the versa but once the workout ends and I've viewed my stats it does not log the exercise on app or in watch. It just seems to disappear.
03-26-2019 12:53
03-26-2019 12:53
03-26-2019 13:30
03-26-2019 13:30
You need to reboot the watch (it’s not picking up heart rate, bpm indicator on watch just shows as two dashes) and you need to change settings on app from auto sync to only sync when you open the app. Been two months and no issues since I did the above. Hope that helps.
03-26-2019 13:43
03-26-2019 13:43
04-14-2019 14:20
04-14-2019 14:20
Since last Tuesday:
Not tracking workouts
Not tracking sleep
I have uninstalled and reinstalled app.
I have rebooted Fitbit
Turned off all-day sync
Nothing is working, anything else you might be able to tell me?
09-16-2019 18:40 - edited 09-16-2019 18:40
I had this same issue! I tried reinstalling the app d and that did not work for me, however resetting the Fitbit itself did! It even included my weight lifting workout I did earlier today that I thought I had lost.
01-15-2020 07:56
01-15-2020 07:56
I am having the same issue. I bought this barely a week ago and this week it has only counts 1 day of exercise. Everything else is tracking. It tracks my active minutes but wont convert those to count towards my exercise. I have delete and re-downloaded the app and restarted the watch.
01-16-2020 19:37
01-16-2020 19:37
I am having same issue. Tracked aerobic workouts last week and now this week have to manually enter minutes. Tracks steps, stairs etc. with no issues. Frustrating!
01-17-2020 04:27
01-17-2020 04:27
01-17-2020 05:07
01-17-2020 05:07
01-17-2020 05:56
01-17-2020 05:56
