Hi @Dean13 Have you seen THIS information about using the P20 Lite?
HOW DO I USE THE FITBIT APP ON MY HUAWEI P20 LITE PHONE?
To use the Fitbit app on your Huawei P20 Lite phone, verify the following settings:
Helen | Western Australia
Best AnswerMy Fitbit will not sync to my Samsung Galaxy Note 10 anymore after the last update. My Fitbit has the wrong time now and I cannot do anything with it. The Fitbit App will not work as well. Somebody HELP PLEASE!!!!!!
Best Answer@Dean13 Umm no, sorry. I have a Versa but not a Huawei - as far as I know I have never even seen one! If you Google you might find a video - I really dont know
Best AnswerHi @LadyFierce try restarting your Versa (I assume you have a Versa) several times. If that doesnt fix it then try all the suggestions in THIS Help Article on syncing problems.
Is the app actually not working? Or is it just not showing correct i formation because the Versa is not syncing? If there seems to be something wrong with the app, uninstall it and then reinstall and log back in.
Best AnswerThen I guess you need to contact Support
Best AnswerThis is not a problem unique to you. Several of us have been having this problem. There have been a number of strings on this over the last few days. Personally, I have gotten online help three times and continue to have the problem. It was initially synched to my computer, which worked fine for almost a year. Since that was not working, a rep suggested switching to my phone. That lasted for a few hours. Apparently it is a problem with software that has not been resolved. Contact Fitbit for help. Perhaps this is not your problem. I found that comparing my time on Fitbit with my phone lets me know when it quits syncing. About once a day it starts syncing for a very brief time. My watch is now three hours behind.
Best AnswerBefore I tried a factory reset on the versa 2 to try to resolve my issue, I was also slowly losing time too and it was behind.
But now the factory reset has made the watch completely useless because it won't pair at all.
More in this thread: https://community.fitbit.com/t5/Versa-Smartwatches/Versa-syncing-issues/m-p/4166720
Best AnswerI have a Pixel 3XL and on my phone I went to the my Bluetooth settings and clicked on "Versa"and clicked "Forget". Then I just let Versa connect on its own. Worked for me!
Best AnswerI did get my report this morning. Up to this point I viewed my fitbit as my best investment of the year. I've lost about 50 pounds since I purchased it last year. I upped steps from 10,000 a day in May to 15000 a day in June to my current amount of 20000 a day, with one day at 25000. As I have progressed to jogging in place, the heart rate monitor has been important for me to know when to slow down as I hit my maximum heart rate. I've also use the calorie counter as a rough guide and subtracted 500 calories as my guide for the next days intake. That allowed me to lose a pound a week. I have about 20 more pounds to go. My doctor also has used the info from the reports. So you can see it is important for me to get this problem fixed. I did get the report. Steps were accurate to the point that it synced. That's why I play with it when I hit my goal. Heart rate doesn't appear to be as accurate, which is key for me. I think I have discovered that once I get it to sync, the times match until I put the watch back on my wrist. That's when the connection seems to break.
