09-08-2018
13:21
08:06
AlejandraFitbit
09-08-2018
13:21
08:06
AlejandraFitbit
I've searched the forum and cannot find an answer! My Versa was at 40% and I believe it died. However; when I put it on the charger the Fitbit logo came up and then the screen went blank. I've tried the soft and hard reset and it's not even working. Is there any other options for it to start working? Is there anything I can do to get it to work? I can't return it to Target as it is past the 30 days. I'm trying to wait it out see if it works, but I don't think it will!
Best AnswerIt sounds as if you have done all the right things. If Target wont exchange then contact support as it should still be under warantee. (Link in my signature)
Helen | Western Australia
09-09-2018
08:07
07:03
09-09-2018
08:07
07:03
It's great to have you here @Pbriand and @NellyG thanks for the input.
I appreciate all the efforts in trying to fix this issue and would like to know if you followed our friend's recommendation and contacted our support team, have they offered a solution for this?
Hope to hear from you soon. ![]()
