Versa not working at all
I've got a Versa (registered in February of 2019, so it's out of warranty).
A little while back (a few weeks ago?) it ceased to wake up when the face was up...meaning that I had to tap the screen or press a button to wake it up.
Last night, the screen was black, and there was no response at all. I thought perhaps the battery had died, so I put it on the charger. When I did, the screen showed it charging and at 0%. Ok, cool...
This morning, I removed it from the charger. It still won't respond, the alarms I have set aren't working, and placing back on the charger shows nothing.
From my devices on my profile:  Firmware version: 32.33.1.30
I should note that I NORMALLY remove it while showering, but I forgot a couple of days ago. I dried it off well after the shower (and, as I understand it, showering should be fine).
Any ideas? Or do I just write it off?
1 REPLY 1
Hi @Twistagain,
Sounds like water got into the Versa while you were in the shower.  Put it in a Ziploc bag filled with white rice and dry it out overnight.  Then proceed to charge it and see if that helps.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
