04-25-2018 03:35
04-25-2018 03:35
I was receiving notifications (email, WhatsApp) on my Versa for the first couple of days but it has stopped working for no apparent reason. I have tried all the usual things like restarting the phone and device and changing the settings but nothing seems to work and I don't know what to try next. Please can you help?
04-25-2018 20:35
04-25-2018 20:35
@PROUD-PSW wrote:OMG called in to fitbit customer care, the rep was amazing... he took the time to do step by step on what to do and guess what, my versa is finally working the way it is suppose to... lol it only took 5 times to call for someone to actually take the time to make me do the right stuff... whoohoo
What was the key to get it working again? My notifications are still very spotty.
Best Answer04-25-2018 20:48
04-25-2018 20:48
@lexi83 wrote:Notifications troubleshooting Someone got back to me on Twitter and gave me a link for troubleshooting. And I’ve got my mums watch working again for notifications. What I did was pushed and hold the button on the left side of the watch (the one that will power your watch on, there’s only 1 button on that side) it will vibrate, then swipe left it will have 2 options one being SCREEN WAKE the other being NOTIFICATIONS. Make sure it says notifications on. If it says off this will be why you are not getting notifications. Hope this works and help solve some of the issues. Good Luck!
Ive attached a screen shot of the trouble shooting and link above ( notifications troubleshooting)
@StarkRaven have you tried the troubleshooting shooting above?
Best Answer04-26-2018 05:14
04-26-2018 05:14
Notifications worked in the afternoon but by evening had stopped. I did try the troubleshooting tips. This morning I uninstalled then reinstalled the app on my phone and they appear to be working again (at least the test call came through).
Best Answer04-26-2018 18:04
04-26-2018 18:04
...and tonight I'm back to NO notifications again.
Best Answer04-27-2018 18:15
04-27-2018 18:15
That worked. Mine was off and that may have happened when I was changing out the band.
04-27-2018 18:31
04-27-2018 18:31
Awesome information. Mine said notifications off. Turned them on and waiting for a text or email now to see if that fixed it.
Best Answer04-27-2018 18:34
04-27-2018 18:34
Glad it’s helped some hope it works for you @Nivrat47
Best Answer04-27-2018 18:39
04-27-2018 18:39
Best Answer04-27-2018 18:48
04-27-2018 18:48
Yes if I’m honest I don’t know why I don’t get regular notifications for emails. I think there ar3 quite a few with the same error being specifically email notifications
Best Answer04-27-2018 18:57
04-27-2018 18:57
@Nivrat47 This is a link I found about notifications to give you a little insight versa notifications info link
Best Answer04-27-2018 19:01
04-27-2018 19:01
It is working well now. Thanks for your help.
05-17-2018 08:44
05-17-2018 08:44
Thank you. I tried that and it worked!
Best Answer10-04-2018 12:24
10-04-2018 12:24
Thank you for sharing this is exactly what was wrong with mine not sure how it got flipped off..
Best Answer10-25-2018 18:55
10-25-2018 18:55
Download the version 2.73
https://fitbit.en.uptodown.com/android/download/1740183
Solution for even after restarting the phone,Notifications are not activating.
Just download this version, everything will be up and running.
Best Answer11-26-2018 13:22
11-26-2018 13:22
You are my hero!!
Best Answer11-26-2018 14:00
11-26-2018 14:00
Received the Versa as gift, but sadly the notification for incoming or missed calls and for text messege I received no notification at all. I had follow all type instruction from different reply in the fibit community and outside the community and the problem still persist. So this item will be return tomorrow after wanting this watch since it first came out. A very unhappy unsatify customer.
Best Answer01-03-2019 17:01
01-03-2019 17:01
Have you tried swiping left 3x on the clock face - hitting tips and making sure Notifications were on and not OFF? When I couldn’t figure out what was going on with my notifications- just going to tips led me to the issue( this must of happened when I was changing my band)
Best Answer01-17-2019 22:14
01-17-2019 22:14
Hi Freddie here.. bought one for fiance .Christmas .. Same problem notifications and receive calls ..works then stops (Android phone) I have reset this I don't know how many times that's very slow then kicks in .. follow on line instructions ..did it yesterday worked for about 12 hrs then quits looks like I am not the only one ..glad for community hopefully a fix ..?
01-18-2019 05:04
01-18-2019 05:04
This watch so glitchy! Terribly frustrating. Notifications for text messages worked fine until a couple of days ago. Yes, everything is updated. Yes, notifications are on. Yes I’ve restarted both phone and watch. Yes I’ve turned Bluetooth off and on again.
Are there any actual fixes for this problem?
Also, the watch has NEVER alerted to emails even though I have the options selected for this.
01-22-2019 22:27
01-22-2019 22:27
