05-22-2019
13:24
06:11
JuanJoFitbit
05-22-2019
13:24
06:11
JuanJoFitbit
When I try and update my fitbit while on wifi it starts to update but doesn’t finish. I have removed the device and started over as well as uninstalled the app
05-22-2019 13:39
05-22-2019 13:39
05-22-2019 20:42 - edited 05-22-2019 20:43
Just adding to what @WavyDavey already said, make sure you're near the router, Versa is in charging dock, and on strong, stable internet connection. You can reboot versa ans restart the process perhaps using different wifi network (e.g. at your friend's or workplace). Alternatively, there's always Bluetooth way as @WavyDavey mentioned.
05-23-2019 06:07
05-23-2019 06:07
@Missy18 Welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the update won't finish.
I'd just like to know if the issue persists or if your Versa could be updated after following the troubleshooting steps that shared @WavyDavey and @Marrrmaduke.
If you found their posts helpful, please accept them as a solution so other users that experience the same issue can find it easier.
Looking forward to your response! ![]()
