01-06-2020 04:53
01-06-2020 04:53
Hi
This morning my versa just switched off by itself, since then i am struggling to get it started. I have tried 10-15sec and 3-5min three button factory reset. No luck. Have the watch for about 2years and this is the first major issue, except the syncing issues.
What to do? Help please.
01-07-2020 06:53
01-07-2020 06:53
@RynoMaritz, welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it won't turn on even though you have restarted it before contacting our forums.
I would like to know if your Versa vibrates when you put it on the charger.
In the meantime, please try the troubleshooting steps that are listed in this help article. This article contains the restart process but you can skip it and proceed with the rest. Finally, try changing the clock face to one developed by Fitbit, not a third party clock face and see if your watch comes back to life.
Keep me posted on the outcome! 😀
Best Answer01-07-2020 07:26
01-07-2020 07:26
Hi
When charging it does not vibrate. I had on charge overnight and retried the factory reset again without any luck. I cannot get it on, so your suggestion of changing the clock face is not possible.
Frustrated and disgussed.
Best Answer01-07-2020 07:34
01-07-2020 07:34
I have also noticed no lights are on at the back....
Best Answer01-07-2020 07:51
01-07-2020 07:52
01-07-2020 07:52
For some reason it shows it is syncing with app, but the screen of the watch is black......
Best Answer01-09-2020 11:57
01-09-2020 11:57
Mine was the same it took quite a few times of turning on the watch and rebooting my device as i use my phone to track my fit bit. After doing this several times over 24hrs it eventually turned on and started syncing and completing the start up linked a new device. If it doesn't work im afraid i would take it back to where you bought it if you still have the receipt and it's in waranty. Apologies i can only go on how i resolved my issues, if it helps then great if not i apologise i can't offer any other advice.
