12-28-2018 13:24
12-28-2018 13:24
I have a brand new Fitbit Versa and it was updated today but the quick reply option isn’t available in the notifications section on the app I have a iPhone 7 up to date on updates can anyone shed some light ?
Best Answer12-28-2018 13:38 - edited 12-28-2018 13:40
Hi, first there was the Today problem after updating, e.g. not showing the new Today screen which makes it possible to choose seven activities it should monitor, now you have this problem. Maybe the same solution will work as for the Today screen, e.g.: put your Versa in the charger and connect it to PC and leave it their resting for about 2 to 3 hours and see whether your problem is solved after this time. Really hope this cause there are a lot of problems mentioned regarding notifications and iPhones, even the by Fitbit supported ones.
Best Answer12-28-2018 14:45
12-28-2018 14:45
Apparently quick reply isn't available on iPhone as Apple haven't added this yet.
https://community.fitbit.com/t5/Versa/Replying-to-Texts-on-the-FitBit-Versa/m-p/2785731#M29273
