01-16-2019
03:39
09:19
MarcoGFitbit
01-16-2019
03:39
09:19
MarcoGFitbit
My versa is linked to my iphone (IOS). Whenever i scroll down to view my notifications on it, it restarts alone and cant even clear the notifications. Any suggestion.
PS: bought it 2 weeks ago
01-17-2019 09:23
01-17-2019 09:23
Hello @Ekouba, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. At this moment, I would like to suggest you to try the following steps:
If your Versa restarts again when checking Notifications, please let us know so we can check this further.
Thanks for your patience and understanding, give these steps a try and let us know in case you need anything else.
01-17-2019 10:20
01-17-2019 10:20
Hello,
i tried everything i found in the forum, it’s still crashing when i view my notifications. The only remaining proposed solution is to reset it to factory settings. I am avoiding to do this since i dont want to lose all the stats on it.
Thank you
02-11-2019 06:58
02-11-2019 06:58
I also have the same problem, tried all the solutions on the forum and still cant fix my device..
I dont know if it’s normal but my device also overcounts my steps even when Im not moving and only charge till 98%.
I loved my fitbit blaze but versa disappoints me..
Best Answer02-11-2019 09:31
02-11-2019 09:31
Hello @Ekouba! thanks for getting back to us, I'm sorry to hear that the troubleshooting provided didn't work, I appreciate you trying it dough. I also apologize for the delay in the response. Have you tried refreshing the notifications? If this doesn't work you can also try un-pairing the Versa and setting it up again as a new device, but don't forget to sync the Fitbit before un-pairing it so you won't loose your information, and you can do the same before doing the factory reset so you won't loose any data, although I will recommend doing the other steps before. Please let me know how it goes! ![]()
Welcome to the Fitbit Community forums @Yujung, too bad that you have the same issue, thanks for trying all the possible solutions that you found on the forums. Please also try the steps I suggested before. About the steps count, please check the following article: How accurate are Fitbit devices? and restart your tracker.
Hope this helps, I will be around! ![]()
Best Answer02-20-2019 12:23
02-20-2019 12:23
I am having the same issues and have tried all of the listed suggestions. I have only had this for two weeks so this is incredibly disappointing. I had no issues with my blaze that’s had for almost 2 years.
Best Answer02-20-2019 12:29
02-20-2019 12:29
@AlexandraFitbit @I am having the same issues where it just shuts down and restarts on its own or when I check notifications. I’ve tried all the listed suggestions and nothing is fixing the issue. I’ve only had this for 2 weeks so this is really disappointing. Any suggestions? I had the Blaze for almost 2 years with no issues at all.
Best Answer02-21-2019 00:09
02-21-2019 00:09
Hey,
I got to the point where I became so irritated and just synched all my data to the iphone app and reset the Versa to a factory setting. That solved the notification issue lol, although it still miss counts my steps.
It’s a hassle but try and reset the device to a factory setting.
Best Answer03-23-2019 21:46
03-23-2019 21:46
@AlexandraFitbit, I am also having the same issue where my Fitbit Versa reboots when I swipe down from the top to view notifications. I was pretty disappointed today when it started happening again, as I have already been through troubleshooting with Fitbit Support (reboot device, factory reset, etc.) and was sent a replacement device. At this point I have to conclude that it is some type of bug. It would be nice to know if this is being considered a known issue by the Fitibit team and if anything is being done to resolve the bug. (A quick search of the community forum shows a lot of results about Fitbit Versa's randomly rebooting.)
