04-20-2018
11:21
11:05
JuanJoFitbit
04-20-2018
11:21
11:05
JuanJoFitbit
The time is 19:21 (7.21pm), but my versa is showing 07:21 (7.21am). Why is this and what is the fix? Thanks.
A sync with your phone or computer should fix it. However, for some reason, it sounds like the Time Zone setting is way off. Go to Fitbit.com Dashboard and click on the Gear Icon at the upper right and then Settings. Scroll down to "Time Zone" and set correctly and then scroll on down and click on "Submit" and then sync your tracker.
@Kerins123 wrote:
Thanks. Yes that was it. Strange how it doesn't drop the 0 off the front in 12hour mode though.
Get Outlook for Android
What was "it"?
