12-31-2020
02:32
05:40
JuanJoFitbit
12-31-2020
02:32
05:40
JuanJoFitbit
The button on the left if my Versa ll doesn't work- it won't press in. Any ideas?
12-31-2020
05:39
11:35
12-31-2020
05:39
11:35
Hi @seagerF, welcome to our Fitbit Community. Regarding the left button issue that your Versa 2 has experienced, I'd like you to clean around the button with a toothpick in order to remove any dust or moisture that may be affecting the functionality of the button.
After this, monitor your watch and see if the issue gets fixed.
Keep me posted on the outcome.
Best AnswerI woke up to same problem this morning. There is nothing to clean, it is pristine. I just got this in July. Any other ideas? I took it off and put it on charger but that hasn’t changed anything yet. Also, it will not sync this morning. Normally I sync upon waking to seesleep stats. It tries to sync for a couple minutes then says couldn’t sync.
10:09
11:35
12-31-2020
10:09
11:35
Hi @Lodolly, thank you for getting back. Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any question arises.
