12-23-2019
03:49
11:05
12-23-2019
03:49
11:05
My Versa is having all sorts of issues. First the touch screen won’t work at all. Second I’m getting no notifications anymore. I have tried a soft reset and a factory reset with no success. Help!
12-23-2019 07:01
12-23-2019 07:01
I'm confused, if the touch screen isn't working, what n this was used for a factory reset.
I would recommend a hard reset but this requires a working touch a screen.
Have you contacted fitbit?
Best Answer12-23-2019 09:32
12-23-2019 09:32
I held down all 3 side buttons then you release the bottom left.. anyway it didn’t work. Couldn’t find how to contact Fitbit directly so came here hoping they’d respond.
Best Answer12-23-2019 10:13
12-23-2019 10:13
For contact info.
Tap the top right corner, tap contact Fitbit.
Or tap the help link below, then on next page tap contact fitbit
Or through the app / help/ contact fitbit
Type this in browser.
Contact.fitbit.com
