05-05-2018
20:55
08:42
AlejandraFitbit
05-05-2018
20:55
08:42
AlejandraFitbit
My Versa is only a week old. It was working great until tonight when the screen just went blank. It is syncing with the app and the battery level is fine. It is not cracked and I was not doing anything unusual when it stopped working, just walking around. Any ideas how to fix this?
05-06-2018 00:32
05-06-2018 00:32
In the hope that this may be just a software glitch I would try restarting your Versa by:
If that doesn't kick it back into life then it may be a hardware issue and your best option would be to contact customer services via: contact.fitbit.com
06-03-2018 15:29
06-03-2018 15:29
Once you contact fitbit customer service ( I did this by chat on their web site) , they will ask you to send a video of your fitbit not working with your complaint number written in the background. They will say that they will get back to you once they have decided that it is really not working. They will send an email saying that they need to know what country you are in, even if you have given this information before. Then you will get another email saying to send back the watch and charger to them with a return label they will send to you. Once they receive it (about 10 days later) they will tell you hopefully that they will send you a replacement. They were sold out when this happened for me, so I am still waiting for my replacement. My process started the first week of May. Good Luck!
06-04-2018
08:44
09:36
06-04-2018
08:44
09:36
A warm welcome to the Community @Schuhflypie and @SteveH thanks for stopping by.
I appreciate all the efforts in trying to fix this issue and I am glad to hear that you are waiting for your replacement. At the moment of receiving it, you just need to do the following from the Fitbit app to set it up:
If you need anything else, do not hesitate to post it. ![]()
07-10-2018 17:11
07-10-2018 17:11
This has just happened to me 😡
what did you do to fix it?
I think it’s pretty bad that I have to go without a product that I payed $350 for when there’s a manufacturer problem. I should be able to do a straight exchange Instore and let the retailers deal with the problem of a faulty product. If it’s faulty they shouldn’t be selling it.
07-10-2018 19:54
07-10-2018 19:54
07-11-2018
07:51
- last edited
yesterday
07-11-2018
07:51
- last edited
yesterday
Welcome to the Forums @KateBannister and @Schuhflypie thanks for the input.
I would like to know if you followed our friend's recommendation and contacted our support team, have they offer a solution for this?
Hope to hear from you soon. ![]()
07-17-2018 05:51
07-17-2018 05:51
Mine has just done the same. Blank screen. Just happened while I was walking. Not wet or dropped or anything. Is there a reset or something other than exchange. I’ve had mine since April 2018
Best Answer07-17-2018 05:54
07-17-2018 05:54
@Gailanderson you could try a restart of the fitbit. It does no harm and can sort out all sorts of issues. Here's how:
07-17-2018 06:27 - edited 07-17-2018 06:28
The same thing just happened to me. Was working fine when I synced it after waking up this morning. Then while I was getting ready for work I noticed my screen wasn't displaying anything when I flipped my wrist to check the time. I've restarted it several times without any luck. You can't turn it off and on when the screen is blank.
07-18-2018 18:05
07-18-2018 18:05
Thank you!
Best Answer07-19-2018 18:29
07-19-2018 18:29
Did you find a solution for this? My Fitbit just did this. 😑 and I’ve already had it replaced once and the new one I’ve had probably for a month. 😢
08-01-2018 11:16
08-01-2018 11:16
Thanks, Steve That worked!
08-02-2018
04:11
09:35
08-02-2018
04:11
09:35
Hey everyone!
I hope you are doing fine. I am glad to see here that for some of you this issue has been resolved. For the ones that keep experiencing this problem, if the restart process process didn't work, feel free to get in touch directly with our support team, I know they will be glad to help you out. For a faster response you can contacted them via chat.
See you around. ![]()
09-23-2018 07:55
09-23-2018 07:55
Resetting it worked for me. Thanks
09-23-2018 08:08
09-23-2018 08:08
My versa has never worked and have been in constant contact with the support for fitbit. Was just sent this warranty info:We would like to share with you that as per our limited warranty, Fitbit does not warrant that the operation of the Product will be uninterrupted or error-free. So, they are stating their product does not have to work and that is that! Buy an apple or garmin get rid of this!
Best Answer09-23-2018 11:02
09-23-2018 11:02
09-23-2018 11:14
09-23-2018 11:14
I've reset my versa 4 times for my problems and it still doesn't work. Customer support tells me they know the problem involves many people and they just can't seem to get it to work. They are not taking back any of the versa's we are just stuck with them.
10-09-2018 11:19
10-09-2018 11:19
My versa died completely in only 3 months of having it...luckily I had a warranty with best buy for this one, but since they no longer offer warranties with fitbit, I went with a SAMSUNG. Good luck
06-10-2019 12:53
06-10-2019 12:53
Getting replacement second time. I had the same issue twice. Both the times after I went for swimming / water park. Customer rep told me that Fitibit had discovered previously that a part was not sealed hence issue with water getting into the watch. Now that has been fixed but still watch has an issue with water. This has shaken my faith in the organization. This tells me that the product is not made and tested per high standards. Management is rolling bad products in the marker without testing them. Bad culture.
