12-20-2018
08:54
09:43
HeydyF
12-20-2018
08:54
09:43
HeydyF
At about 9.15pm IST today, 20th Dec 2018, the screen of my Fitbit Versa went blank. The battery was fully charged in the morning and there is sufficient charge. Tried everything to activate. No luck. Advice.
Best Answer12-20-2018 09:34
12-20-2018 09:34
Hi, did you also tried to do a factory reset, has to be done sometimes several times to activate the Versa again. Press and hold all three buttons untill you feel a strong vibration. After having felt that release the right lower button. If this does not work for you, please contact Customer Support: https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs .Good luck!
Best Answer12-21-2018 09:42
12-21-2018 09:42
Hey @Sukumar_R, let me give you a warm welcome to the Community! What happens when you charge your Versa? Can you see that is charging? Have you try to restart your Versa? If you haven't, please follow these instructions.
Thanks for your help @SunsetRunner!
Let me know how it goes!
